FAQ - skrzynie biegów, przełożenia |
Wiek: 41 Dołączył: 10 Kwi 2006 Posty: 3110 Skąd: Krosno Odrz.
Wysłany: 28 Paź 2011, 10:30 FAQ - skrzynie biegów, przełożenia
IB5, BC4/5:
4 i 5 biegowe skrzynie biegów FWD. Sprzęgło sterowane mechanicznie, 20mm x 17 wałek wejściowy.
Pojemność oleju: 4 biegowa 2.8l, 5 biegowa 3.1l.
Olej przekładniowy SAE80.
Montowane w:
Ford Fiesta Mk1 / Mk2 / Mk3
Ford Escort / Orion Mk3 / Mk4 / Mk5
| Kod: | ----------------------------------------1----+-2----+-3----+-4----+-5----+-F----
Escort RS turbo S1 ---LSD-------------- 3.15 | 1.91 | 1.27 | 0.95 | 0.76 | 4.27
Escort RS turbo S2 ---LSD-------------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 3.82
Escort RS1600i mk3 ------------------- 3.15 | 1.91 | 1.27 | 0.95 | 0.83 | 3.84
Escort XR3 5spd ----------------------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 3.84
Escort XR3i 5spd MFI ------------------ 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 4.27
Escort XR3i 5spd EFI ------------------ 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 4.06
Fiesta mk2 1.0 5spd ------------------- 3.58 | 2.04 | 1.35 | 0.95 | 0.76 | 4.29 (4spd 4.06 )
Fiesta mk2 1.1 5spd ------------------- 3.58 | 2.04 | 1.35 | 0.95 | 0.76 | 3.84 (4spd 3.58 )
Fiesta mk2 1.3+1.4 5spd --------------- 3.58 | 2.04 | 1.35 | 0.95 | 0.76 | 3.84
Fiesta mk2 1.6 diesel 84-89 ----------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 3.33
Fiesta mk2 XR2 ----------------------- 3.58 | 2.04 | 1.35 | 0.95 | 0.76 | 3.84
Fiesta mk2 XR2 (early?)--------------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 3.58
Fiesta mk3 1,1 hcs -------------------- 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 4.06
Fiesta mk3 1,3 hcs / 1,4cvh ----------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 4.06
Fiesta mk3 RS Turbo ------------------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 3.82
Fiesta mk3 RS1800 --------------------- 2.86 | 1.91 | 1.41 | 1.10 | 0.87 | 3.82
Fiesta mk3 1.8 diesel 89-95 ver.B ----- 3.58 | 1.93 | 1.28 | 0.95 | 0.76 | 3.82
Fiesta mk3 XR2i CVH ------------------- 3.15 | 1.91 | 1.28 | 0.95 | 0.76 | 4.069 |
IB5:
Późniejsze standardowo montowane skrzynie 5 biegowe w Fordach FWD od ok 1995 roku.
Sprzęgło sterowane hydraulicznie, 20mm x 17 wałek wejściowy.
Pojemność oleju: 2.8l.
Montowane w:
Ford Ka
Ford Focus 1.4 / 1.6 / 1.8
Ford Fiesta
Ford Puma
Ford Escort Mk6
| Kod: | -----------------------------------1----+-2----+-3----+-4----+-5----+-F----
Fiesta mk4 1,25 zetec-se --------- 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 4.27 (4,25)
Fiesta mk4 1,25 zetec-se--ver.2 -- 3.58 | 1.93 | 1.28 | 0.95 | 0.76 | 4.27 (4,25)
Fiesta mk4 1,3 ------------------- 3.58 | 1.93 | 1.28 | 0.95 | 0.76 | 4,06
Fiesta mk4 1,4 zetec-se ---------- 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 4.27
Fiesta mk4 1,8D ------------------ 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 3.82
Fiesta mk5 1,25 zetec-se --------- 3.58 | 1.93 | 1.28 | 0.95 | 0.76 | 4.06
Fiesta mk5 1,3 ------------------- 3.58 | 1.93 | 1.28 | 0.95 | 0.76 | 3.82
Fiesta mk5 1,4 zetec-se ---------- 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 4.06
Fiesta mk5 1,6 sport zetec-se ---- 3.15 | 1.93 | 1.28 | 0.95 | 0.76 | 4.25
Fiesta mk5 1,8D ------------------ 3.58 | 2.04 | 1.32 | 0.95 | 0.76 | 3.82
Fiesta mk5 1,8DI ----------------- 3.15 | 1.93 | 1.28 | 0.95 | 0.76 | 3.61
Puma 1,7-zetec-se ---------------- 3.15 | 1.93 | 1.41 | 1.11 | 0.88 | 3.82
Puma Racing 1,7-zetec-se ---LSD--- 3.15 | 1.93 | 1.28 | 0.95 | 0.76 | 3.82 |
Fiesta MK6 i prawdopodobnie przełożenia jak w MK5, oprócz diesli CR.
O MK7 nic konkretnego jeszcze nie znalazłem.
Dla większości będzie jeszcze taki wykres z Excela:
Jak są jakieś błędy to piszcie.
Dane będą uzupełnianie. |
| Ostatnio zmieniony przez Marcin 30 Paź 2011, 12:39, w całości zmieniany 56 razy |
Princessa of Ułęż
Wysłany: 28 Paź 2011, 19:44
z escortem mk3 xr3i to ten dyfer 4,27 był przy mechanicznym wtrysku, przy EFI był 4,06. jeszcze brakuje skrzyni od MK6 ST ale niestety nie mam tych danych. wiem ze coś tam bylo inne. a i jeszcze obudowa co by spiąć z 2,0 16v.
a i moze jeszcze: skrzynie z Escorta RS Turbo (obie wersie) oraz ta z Pumy Racing miały szperę. Ale da się je wsadzać do każdej innej skrzyni IB5/BC. |
Wysłany: 29 Paź 2011, 11:35
ok, poprawiłem escorta. Co do mk6 st coś mi się przypomina, że czytałem gdzieś o tym na jakiejś stronie.
Ogólnie tych, o których nie ma żadnych informacji, można je uzyskać metodą na prędkość+obroty silnika, wtedy w excelu będzie można obliczyć przełożenia, a na pewno poszczególne przełożenia będą się powtarzały jak w poprzednich modelach - te wyliczenia głównie będą dotyczyły mk6 diesli i st. |
Wiek: 35 Dołączył: 08 Lut 2009 Posty: 2600 Skąd: Poznań
Wysłany: 29 Paź 2011, 12:33
hmmm, nie chce sie czepiać, ale są rozbiezne informacje z tymi w książce sam naprawiam oraz tymi w temacie podwieszonym o danych hcs 1.3
PRZEŁOŻENIA SKRZYNI BIEGÓW
1 bieg 3,58 : 1
2 bieg 2,04 : 1
3 bieg 1,32 : 1
4 bieg 0,95 : 1
5 bieg 0,76 : 1
Wsteczny -3,62 : 1
Przełożenie osi 4,06 : 1 |
Wysłany: 29 Paź 2011, 13:18
| ja mam takie dane jak umieściłem, wycinek książki (nie pamiętam jakiej) wklejony przez kogoś tutaj na forum, któryś jest błędny albo ford montował oby dwie... |
madek
Imię: Kuba
Wysłany: 29 Paź 2011, 13:41
luk-90, w książce sam naprawiam są moim zdaniem błędne dane, tak samo odnośnie rs1800. te które Marcin wkleił pokrywają się z prospektem rs1800, w książce są zupełnie inne. jednak bardziej wierze prospektowi prosto od forda |
konxx91
Wysłany: 29 Paź 2011, 17:51
Muszę przyznać, że bardzo przydatny temat. Ale mam jeszcze co do tego parę pytań, bo już wszystko mi się pomieszało. Na podstawie pierwszej tabelki wynika, że wszystkie te skrzynie są zamienne.
1) Prawda czy nie ?
Od razu przypadła mi do gustu skrzynia z rs1800, z tym że z przełożeniem głównym 4,27.
2) Da rade taki mix zbudować ?
3) Będzie to pasowało do xr2i ?
4) Czy jest możliwość wymiany przełożeń poszczególnych biegów pomiędzy tymi skrzyniami na przykład żeby do skrzyni z rs1800 na miejsce 5 wrzucić 4 z xr2i ?
Może są to trochę głupie pytania opierające się na jakimś dziwnym projekcie, ale chciałbym to wiedzieć. Pozdro. |
Model: Ford Fiesta Mk1`81
Wersja: Turbo
Wysłany: 29 Paź 2011, 19:03
Ad1 : Nie . Generalnie i skrótowo - skrzynie są wymienne do modelu mk3 ( fiesta ) później zaczynają się schody .
Ad2 : Nie
Ad3 : Nie bo nie zbudujesz
Ad4 : Nie .
Pytania nie są głupie . Zanim rozłożyłem pierwsze IB5 myślałem , że odpowiedzi to 4*tak . |
Bad Boys Racing Team
ADHD/Adrenaline |
Wysłany: 29 Paź 2011, 23:43
Możesz poprawić/dopisać mk5 DI:
3,154
1,926
1,281
0,951
0,756
3,61
Czyli wychodzi, że to klon skrzynki ze sporta, z tą różnicą, że przełożenie główne jest inne. Dziwne trochę... |
konxx91
Wysłany: 30 Paź 2011, 17:29
No ale przełożenia główne chyba można mieszać pomiędzy skrzyniami mk3 IB5 ?
Na przykład RS1800 z głównym od xr2i, albo escorta 1.3 (tam było z tego co gdzieś wyczytałem 4,27) |
Wersja: Turbo
Wysłany: 30 Paź 2011, 18:52
Nie można .
Duże koło zdejmiesz z mechanizmu różnicowego , małego nie zdejmiesz z choinki |
ADHD/Adrenaline |
Princessa of Ułęż
Wysłany: 30 Paź 2011, 19:56
| Żółwik Tuptuś napisał/a: | Nie można .
ale mozna wsadzić koło talerzowe z xr2i 8v do skrzyni z 1,8 16v. zębatka na walku jest taka sama i ma ta sama ilość zębów. |
Wersja: Turbo
Wysłany: 30 Paź 2011, 20:45
Skoro małą zębatka jest taka sama ( ? ) to duża też musi być taka sama .
Skoro koło talerzowe jest inne , to zębatki na choince też muszą być inne .
Inaczej nie będą pasowały kształty zębów do siebie ( Mac Gywer mnie tego nauczył )
Pochodzi to , tylko jak długo ( o ile wogóle )
Poza tym składanie używanych kół nie w parach w któych chodziły to kolejny zabawny pomysł .
W skrzyni IB5 tej z rozrusznikiem z przodu zmienić można mechanizm różnicowy na inny . Nic więcej . Koniec i kropka . |
ADHD/Adrenaline |
kenczorf
Imię: Grzegorz
Wiek: 40 Dołączył: 12 Kwi 2007 Posty: 1874 Skąd: Tarnów
Wysłany: 19 Sty 2012, 12:38
| ma ktos przelozenia z mk3 1.6 16v? |
_________________ Cichociemna
Princessa of Ułęż
Wysłany: 19 Sty 2012, 13:34
| kenczorf napisał/a: | | ma ktos przelozenia z mk3 1.6 16v? |
takie same jak w 1,8 16v tylko dyfer 4,06 a nie 3,82(3,84) |
kenczorf
Imię: Grzegorz
Wysłany: 19 Sty 2012, 13:41
| PumaRST napisał/a: | | takie same jak w 1,8 16v tylko dyfer 4,06 a nie 3,82(3,84) | mowisz o wersji 105km czy 130? A moze tam byly takie same?
| Marcin napisał/a: | | Ogólnie tych, o których nie ma żadnych informacji, można je uzyskać metodą na prędkość+obroty silnika, wtedy w excelu będzie można obliczyć przełożenia, | masz takie makro utowrzone? |
| Ostatnio zmieniony przez kenczorf 19 Sty 2012, 13:48, w całości zmieniany 1 raz |
Princessa of Ułęż
Wysłany: 19 Sty 2012, 13:45
| to samo |
Wysłany: 19 Sty 2012, 14:11
Bierzcie i jedzcie z tego wszyscy ;]
Prawa autorskie, etc. zastrzeżone, więc jak zobaczę to na obcym serwisie (a już nie daj z usuniętymi informacjami dot. pochodzenia), to będę ścigał (a wrednym ch**** jestem, więc nie radzę próbować ;] ).
Póki co nie zezwalam na kopiowanie i przerabianie, bo arkusz może jeszcze zawierać jakieś drobne błędy - takowe należy zgłaszać. Finalna wersja i tak będzie za frei, pod warunkiem zachowania creditsów. Kontaktów na forum do mnie jest dosyć, w samym arkuszu też jest zawarta stosowna informacja. Z ew. requestami dodatkowych ficzerów tak samo - zgłaszać.
Wersja dla Office 2007 (SP3)
Wersja dla Office 97-2003 |
Wysłany: 19 Sty 2012, 14:36
| PumaRST napisał/a: | | kenczorf napisał/a: | | ma ktos przelozenia z mk3 1.6 16v? |
a escort 1.6 16v ma takie same przełożenia jak mk3 1.6 16v? |
Princessa of Ułęż
Wysłany: 20 Sty 2012, 08:11
| przełożenia tak ale co do dyfra nie jestem pewny na 100% wydaje mi się że tak |
