Przesunięty przez: Żółwik Tuptuś 10 Cze 2006, 09:48 |
felgi 17" |
Piesek
Wiek: 37 Dołączył: 28 Sty 2005 Posty: 1226 Skąd: Gdańsk
Wysłany: 17 Wrz 2005, 16:53 felgi 17"
One of the most asked questions regarding Fiesta styling is "Can I fit 17" wheels?". The answer is yes, but there are several things that you will need to do in order to accomodate this size of rim.
1) Modify the arches
The arches on a Fiesta were only made to accommodate the 13" or 14" standard wheels that Ford fitted to the car. If you fit your 17"s straight on they will catch on the arch lip and scrape on the plastic arch liners. Some cars, such as Saxos, require major effort, including relocation of bumper mounts and washer tanks to fit 17"s, fortunately, this isn't necessary on a Fiesta.
2) Alter the rear suspension set up.
The problem here is the wheels making contact with the spring cups, or the spring itself on coilover setups. On later model Fiestas, those made after 1994, this is not evident as Ford changed the design of the rear shocks, but if the Ford shocks are replaced with aftermarket items or coilovers, the issue will arise.
3) Limit the steering rack.
The size of the wheels may cause the tyre to come into contact with the crossmember inside the front arches. This is fairly simple, attach a couple of hose clips to the steering rack.
This article will explain what work is required, both with the arches and the suspension. The article is written assuming you have an XR or RS model with the plastic arch extensions. If you don't, ignore the steps relating to them.
IMPORTANT NOTE: please read the disclaimer before proceding.
Offset
If you image looking at the wheel front on (as in if you are looking at the the front or rear of the car). Then imagine that you have X-ray eyes and can see through the wheel and see the face that mates up to the hub. Offset is the distance (in mm) that this face is from the the centre-line of the wheel. The standard Ford offset is ET35. Obviously if the face is to the right of the centre-line (looking at the left hand wheel on the front of the car), the wheel will stick out further. If it is to the left of the centre-line then the wheel will stick in further. Obviously, the idea is to get a matching offset (+ or - a few mm) to the standard car so that the wheels do not stick out too far (as they will touch the arches on cornering or with heavy loads) or stick in too far (will foul the shock absorbers / springs). Incorrect offset can be corrected using wheel spacers, for instance 3mm spacers will change ET38 to ET35. If the wheels were are ET25 they would protrude 10mm too far, this cannot be corrected using spacers.
Wheel Sizes
If possible, stick to a 7 inch width. Most 17"s are this wide, but some manufacturers only produce rims in a 7.5". Momo and Smiths are two companies that do this. 8x17" may fit, but the trouble with 8" width is that the fronts will stick out past the edge of the arches, which will fail an MOT.
Tyres
When running 17"s, 205/40s are the recommended tyre size. The exact width can differ quite a bit between different manufacturers, so a 205 Pirelli may be narrower than a 205 Yokohama for instance. The Toyo Proxy T1-S is known for being a fairly narrow 205.
Arches - Front
The work involved here depends on how much you want to lower the car. It makes sense to remove as much as possible thereby eliminating any chance of the wheels catching. The first step is to remove the arch trims to leave the wing and metal arch lip visable. The front wings do not carry any of the load of the car, all this is done throught the crossmembers, so it is possible to remove large amounts of metal without compromising the strength of the car.
The splash guards will need to be taken out. They can be trimmed and refitted later or left out completely, necessary if the car is very low, although this can lead to grit and dirt inside the engine bay so it's a good idea to modify them to fit further up. Another idea is to cut them up and make smaller splash guards that fit in key areas, such as under the air filter.
The drilled holes in the wing that the bodykit arch trims bolt to will now be visable. The metal lip needs to be removed completely. For maximum clearance it can be cut back to just before the kit mounting holes. This will obviously look a little odd until the trims are refitted and in the case of non kitted cars, just remove the lip. An air hacksaw is an ideal tool for this as the speed of the blade motion gives a neat cut. After cutting, repaint any areas of bare metal to prevent corrosion.
The topmost bolt that holds the trims on will need to be ground down, as this will catch the tyre if left. Upon refitting of the trims use bodykit adhesive or an adhesive trim repair type tape. Next cut the lips back on them completely. This can be done with a sharp stanley knife which also gives a neat cut. They should be trimmed flush at the top and then begin to taper out and the cutting line should just pass near where the screw hold them on near the bottom of the doors.
Arches - Rear
The rear arches don't require cutting as much as the front, due to the rear wheels not turning. However there is a welded seam on the lip, which limits the amount of metal that can be removed. As it is two panels welded and folded over, the metal is thicker and the air hacksaw may not be sufficiant to cut through it. In this case an angle grinder is the solution.
Another alternative is to get the rear arches professionally rolled using a special tool. The paint is heated up to avoid cracking then the rolling tool is attached to the hub and a wheel on the arm folds the metal back.
Altering the rear suspension
There are a couple of methods for doing this. The first is to space the wheels out to clear the spring cups or springs themselves. The disadvantage of this is that it will bring the wheels closer to the arch where they are more likely to catch.
Wheels can be spaced out in two ways. The first is to use regular wheel spacers, click here for details on spacers. The preferred method is to use spacer plates. Click here for spacer plate info.
Depending on the width of the wheels it may be possible to obtain the required clearance by simply removing the shock absorber, rotating 180 degrees and refitting. The spring cup is higher on one side than the other and in some cases rotating the cup is sufficiant.
Special thanks to Mike Rainbird, Norfolk RSOC Chairman, and Paul B (mmogenuius) for their help with this article. |
Kowal [Usunięty]
Wysłany: 17 Wrz 2005, 16:58
Siemka ! Wrzuciłem to w program tłumaczacy wiec co nieco moze byc nietak ! Ale jest ! Moze cos zrozumiesz , bo po polsku to zbytnio niejest nieczytalem calosci .Pozdrawiam
Tekst Przetłumaczony :
One spytany pytań dotyczących sttylizowanie Fiesta jest " I mogę pasować na 17" kołami?". Odpowiedź jest tak, ale są kilka rzeczy, że będziesz potrzebował zrobić żeby accomodate tę wielkość obręczy.
1) Modify wygina się łukowato
Wygina się łukowato na Fiesta tylko został zrobiony, by zaakomodować 13" albo 14" standardowe koła, które Ford dopasowane do samochodu. Jeśli pasowałeś na twojego 17"s prosto na oni chwytają figlarną wargę i zgrzytają na plastycznych figlarnych liniowcach. Jakieś samochody, takie jak Saxos, wymagaj głównego wysiłku, zawierając przeniesienie wierzchowców zderzaka i czołgów pralki mechanicznej, by pasować na 17"s, na szczęście, to nie jest konieczne na Fiesta.
2) Alter wznosić zawieszenie umieścił.
Problem tutaj jest kołami robiącymi kontaktu z wiosennymi filiżankami, albo samą wiosną na strukturach coilover. Na późniejszy model Fiestas, te goniły 1994, to nie jest oczywiste jako Ford zmienił projektowanie wznosić szoków, ale, jeśli szoki Ford będą zastąpione z rzeczami aftermarket albo coilovers, zagadnienie powstanie.
3) Limit półkę kierować.
Wielkość kół może spowodować oponę, by zetknąć się z crossmember wewnątrz przód wygina się łukowato. To jest dość proste, przymocowują kilka spinaczy pończochy do półki kierować.
Ten artykuł wyjaśni co praca jest wymagana, zarówno z wygina się łukowato i zawieszenie. Artykuł jest napisany przyjmując, że masz XR albo model RS z plastycznymi figlarnymi rozszerzeniami. Jeśli nie robisz, ignorują kroki wiążące się z nimi.
WAŻNA NOTATKA: proszę przeczytało zaprzeczenie przed proceding.
Wyrównał
Jeśli obrazujesz spoglądanie u steru przodu dalej (jako, w jeśli patrzysz na przód albo stajesz dęba samochodu). Wtedy wyobraź sobie, że masz X-ray oczy i móc przejrzeć koło i widzieć stawać, wobec który parzy się, aż do piasty. Jest wyrównana odległość (w mm) że ta twarz jest z centrum - linii koła. Standardowy Ford wyrównał jest ET35. Oczywiście, jeśli twarz będzie w prawo centrum - linii ( patrzącej na lewe pokrętło na przodzie samochodu), koło będzie sterczało dalej. Jeśli to ma w lewo centrum - kreskować wtedy koło utkwią w dalej. Oczywiście, pomysł ma dostać pasować wyrównał (+ albo - kilku mm) do standardowego samochodu więc, że koła nie sterczą zbyt daleko (ponieważ oni dotkną się wygina się łukowato na skręcaniu albo z ciężkimi ładunkami) albo kij w zbyt daleko ( zanieczyszczą amortyzatory / wiosny). Niepoprawne zrównoważenie może zostać poprawione używając spacers koła, na przykład 3mm spacers zmieni ET38 do ET35. Jeśli koła były są ET25 oni wysunęliby 10mm zbyt daleko, to nie może zostać poprawione używając spacers.
Sizes koła
Jeśli możliwe , trzymać się 7 szerokości cala. Najwięcej 17"s jest tym szerokim, ale jacyś producenci tylko produkują obręcze w 7.5". Momo i Smiths jest dwoma przedsiębiorstwami, które robią to. 8x17" może pasować, ale kłopot z 8" szerokość jest, że przody będą sterczały po krawędzi wygina się łukowato, który nie zdoła MOT.
Opony
Kiedy prowadząc 17"s, 205/40 s jest polecić wielkością opony. Dokładna szerokość może różnić się całkiem trochę między różnymi producentami, więc 205 Pirelli może być węższe niż 205 Yokohama na przykład. Toyo Proxy T1-S jest znany dla bycia dość wąski 205.
Wygina się łukowato - Front
Praca włączyła tutaj zależy od jak dużo chcesz obniżyć samochód. To ma sens, by przenosić się tyleż jak możliwy tym samym eliminując jakąś szansę kół chwytających. Pierwszy krok ma usunąć łuk nie angażuje się, by zostawić skrzydło i metal visable wargi łuku. Przednie skrzydła nie noszą jakiegoś z ładunku samochodu, to wszystko jest zrobiony throught crossmembers, więc to jest możliwe, by usunąć duże ilości metalu bez kompromitowania siły samochodu.
Straże plusku będą potrzebowały zostać wzięta. Oni mogą zostać uporządkowany i refitted późno albo odeszły zupełnie, konieczny, jeśli samochód jest bardzo niski, chociaż to może zaprowadzić, by skrzypnąć i brudy wewnątrz zatoka silnika więc to jest dobry pomysł, by zmodyfikować ich, by pasować dalej. Inny pomysł ma pociąć ich i zrobić mniejszy plusk chroni to wstawiał kluczowe obszary, takie jak pod powietrznym filtrem.
Wywiercone dziury w skrzydle, że łuk bodykit porządkuje rygiel, by teraz będzie visable. Potrzeby wargi metalu, by zostać usunięty zupełnie. Dla maksymalnego pozwolenia to może zostać ucięte do tuż przed ekwipunkiem wsiadający na dziury. To oczywiście spojrzy mało nieparzystego, aż stany są refitted i w przypadku nie wyposażony samochody, tylko usuwać wargę. Powietrzny hacksaw jest idealnym narzędziem do tego jako szybkość ruchu ostrza daje schludnego uciął. Po cięciu, przemaluj jakieś obszary nagiego metalu, by zapobiec korozję.
Najwyższy rygiel, który trzyma stany będzie potrzebował zostać zmielony, ponieważ to złapie oponę, jeśli odeszły. Na odremontowywaniu stanów używają kleju bodykit albo przylegającej uporządkowanej kasety typu naprawy. Następny obciął wargi na nich zupełnie. To może zostać zrobione z ostrym nożem stanley, który też daje schludnego uciął. Oni powinni zostać uporządkowany strumień w szczycie i wtedy zacznij zwęzić się i linia cięcia powinna tylko przejść bliski, gdzie śruba trzymają ich blisko dna drzwi.
Wygina się łukowato - Rear
Stawaj dęba wygina się łukowato nie wymagać ucinania tyleż jako przód, z powodu wznosić kół nie obracających. Jednakże jest zespawany szew na wardze, która ogranicza ilość metalu, który może zostać usunięty. Ponieważ to są dwa panele zespawane i złożone ponad, metal jest grubszy i powietrzny hacksaw nie może być sufficiant, by uciąć przez to. W tym przypadku szlifierz kąta jest rozwiązaniem.
Inna alternatywa ma dostać się stawać dęba wygina się łukowato profesjonalnie potoczony używanie specjalnego narzędzia. Farba jest podgrzana, by uniknąć pękania wtedy toczącego się narzędzia jest były przywiązany do piasty i koło na ręce składa metal z powrotem.
Zmieniając wznosić zawieszenie
Są kilka metod dla robienia to. Pierwszy ma kosmiczny koła, z by oczyścić wiosenne filiżanki albo sam wiosny. Wada tego jest, że to przyniesie koła bliżej łuku, gdzie oni są prawdopodobniej, by chwycić.
Koła mogą zostać rozstawione z w dwóch drogach. Pierwszy ma użyć regularnego spacers koła, klikają tutaj dla szczegółów na spacers. Preferowana metoda ma użyć płyt spacer. Kliknąć tutaj dla informacji płyty spacer.
Zależąc od szerokości kół to może być możliwe, by otrzymać wymagane pozwolenie do po prostu usuwania amortyzatora, obracania 180 stopni i odremontowywania. Wiosenna filiżanka jest wyższa na jednej stronie niż inny i w jakichś przypadkach obracających filiżankę jest sufficiant.
Specjalne dzięki Mike Rainbird, Chairman Norfolk RSOC i Paul B (mmogenuius) dla ich pomagać w tym artykule.
Moze cos zrozumiesz , nieczytalem calosci . |
Członek Honorowy FKP
Wiek: 46 Dołączył: 16 Mar 2005 Posty: 1367 Skąd: Zamość/Łódź
Wysłany: 17 Wrz 2005, 17:23
Kowal napisał/a: | .chwytają figlarną wargę i zgrzytają na plastycznych figlarnych liniowcach.
przepraszam ale popłakałem się ze śmiechu ..eh te programy translatorskie potrafia dostarczyc prawdziwej rozrywki |
_________________ dużo fiest było ..jeszcze jakaś będzie |
Piesek
Wysłany: 17 Wrz 2005, 18:10
coś Loy mi to pachnie sexem Nie no niepowiem niezły ubaw miałem jak to czytałem Raczej niepomogło mi to a miało w przemyślunkach nad 17" |
Wysłany: 18 Wrz 2005, 02:55
piesek jak tam Angole takie głupoty i bezeceństwa wypisuja to lepiej nie drąż juz tematu i za przykładem kolego LOY-a zamontuj koła 195/45/15.
Loy poleca |
NOWITEK
Wiek: 46 Dołączył: 21 Cze 2004 Posty: 188 Skąd: Małopolska
Wysłany: 18 Wrz 2005, 09:14
Eeeeee Ja tam polecam DUZE kółka , wrzuciłem do swojej i było OK (a niska jest ) Co prawda małe ET miały te 17 i były trochę w środku (trzeba by było jakieś dystanse założyć )ale weszły ;-)
A na 16 też bedzie
maerik
Silnik: 1.4i/71KM
Wiek: 40 Dołączył: 14 Kwi 2005 Posty: 722 Skąd: Kraków
Wysłany: 21 Wrz 2005, 17:48
LOY napisał/a: | piesek jak tam Angole takie głupoty i bezeceństwa wypisuja to lepiej nie drąż juz tematu i za przykładem kolego LOY-a zamontuj koła 195/45/15.
Loy poleca |
Pewnie, zgadzam sie z LOYEM 15, 16 cali do starszej fiesty to max... powyzej tego to juz nie na nasze drogi a i wyglada jakos... dziwnie...
Nie kazdy lubi Ewe Sonnet... |
