MMOexp POE2 Zero-Loot Challenge: Beat the Entire Endgame
Lilidala
Model: Ford Fiesta Mk2`89
Wersja: Gold
Silnik: 1.4i/71KM
Imię: pikihong hong
Ostrzeżeń:
 6/6/7
Wysłany: Dzisiaj 11:24   MMOexp POE2 Zero-Loot Challenge: Beat the Entire Endgame
Summary
Bored of the normal Path of Exile 2 loot grind? Take on the ultimate hardcore challenge: a Gold-Locked run where every item drop is off-limits. No equipment, no currency, no flasks—your only legal resources are POE2 Currency and Waystones. How do you finish the campaign and push into the Atlas without ever picking up gear or even a life flask? This guide covers every rule, resource management strategy, and progression route you need to complete the game under these extreme restrictions while experiencing Path of Exile 2 in a completely different way.
Lock in the Challenge Rules: Touch One Illegal Drop and the Run Is Over
This section is for anyone interested in trying the challenge. Understanding the rules from the beginning prevents accidental mistakes that invalidate the run.
Every item hidden by your loot filter is completely off-limits. This includes:
Equipment
Currency
Flasks
Crafting materials
Random item drops
The only two exceptions are:
Gold
Waystones
These are the only legal resources used to progress through the game.
All equipment upgrades must come exclusively from:
Quest rewards
Vendor purchases
Ritual rewards
Any gear obtained from other sources violates the challenge rules.
Your ultimate objective is to defeat both the Arbiter of Ash and the Arbiter of Divinity in Softcore Solo Self-Found without picking up any conventional loot.
Plan Your Gems Carefully: Support Gems Are the Biggest Bottleneck
This section is aimed at players starting the challenge and deciding which gems to use.
The highest Active Skill Gem you can realistically obtain during the entire run is Level 13. Since you won't have access to regular loot progression, choose your core active skills early and avoid unnecessary changes.
Support Gems are even more restrictive. In most cases, you'll only have access to Level 1 and Level 2 Support Gems, with no reliable way to obtain higher-level versions.
Because every Support Gem is valuable, treat each choice as a long-term commitment.
Avoid locking yourself into Brutality Support too early. While it provides solid physical damage initially, elemental support gems offer much stronger synergy later in the challenge and make future transitions considerably smoother.
Spend Every Gold Coin Wisely: Gambling Is a Waste
This section is for players tempted to gamble for equipment as soon as they accumulate some gold.
The odds of finding meaningful upgrades through gambling are extremely low. Most gambled items are random magic-quality gear that provides little or no practical improvement.
Instead, save 20,000–30,000 Gold and repeatedly check vendor inventories for high-quality upgrades.
Your highest-priority purchases should be:
+2 Minion Helmet
High Energy Shield equipment
High Resistance armour
High-recovery Life Flasks
These items provide the largest improvements to survivability under the challenge's restrictions.
Even outside this challenge, this disciplined resource management strategy is useful for standard POE2 characters, helping players avoid wasting valuable currency on inefficient upgrades.
Replace Limited Support Gems with Smarter Combinations
This section is for players struggling with low damage because of limited Support Gem availability.
Once you've finished using Brutality Support during the early game, transition into elemental-focused support gems.
The strongest options include:
Concentrated Effect
Magnified Effect
Added Chaos Damage
Added Fire Damage
Use Magnified Effect while clearing maps to increase area coverage.
When fighting bosses, switch to Concentrated Effect to maximize single-target damage.
If necessary, it's even worthwhile creating a new character just to farm a useful low-level Support Gem. A single well-chosen Support Gem often provides a larger damage increase than several equipment upgrades combined.
Transition Your Passive Tree from Physical to Cold Damage
This section is intended for players whose passive tree is heavily invested in physical damage but are struggling with both damage and survivability.
Instead of continuing with pure physical scaling, gradually transition into Cold Damage.
Maintain physical damage as your base while converting as much of it as possible into Cold Damage.
Cold damage naturally provides chilling effects, improving both crowd control and survivability while also interacting much better with elemental Support Gems.
There's no need for a complete passive tree reset. Simply continue expanding from your existing physical nodes toward Cold Damage clusters, preserving your previous investments while increasing overall damage from approximately 27,000 to 31,000.
Vendors Become Your Primary Loot Source
This section is for players who haven't yet developed the habit of checking vendors regularly.
Every time you complete a major campaign or mapping milestone, immediately return to every previously visited town and refresh each vendor's inventory.
Always prioritize purchasing:
+2 Minion Helmet
High Energy Shield gear
High Life armour
High Resistance equipment
High Damage Lightning Charm
When necessary, create additional characters to purchase inexpensive:
Transmutation materials
Regal materials
Artisan materials
Although this process takes time, it remains one of the few legal methods of acquiring crafting resources under the challenge rules.
Prepare Properly Before Entering Maps
This section is designed for players who rush into maps only to get overwhelmed by ordinary monsters.
Before entering the Atlas, save at least 90,000 Gold.
Use that gold to acquire from vendors:
Resistance gear
Better shields
+2 Minion Helmet
Don't attempt mapping with underdeveloped equipment simply because you cannot rely on dropped upgrades.
Also collect sufficient:
Magic Waystones
Rare Waystones
Since Waystones are your only legal method of opening maps, maintaining a healthy supply is essential for continuous progression.
Finally, gather every useful low-level Support Gem available and prepare separate setups for:
Mapping
Boss encounters
Having both configurations ready before entering maps eliminates unnecessary interruptions later.
If your Lightning Resistance remains negative when you first begin mapping, don't panic. Continue upgrading through vendor purchases, and your defenses will gradually improve.
Prioritize Survivability Throughout the Mapping Stage
This section is for players who reach maps but are repeatedly killed by higher-tier monsters.
As monster damage increases dramatically, your first priority should no longer be increasing DPS.
Instead:
Cap all elemental resistances.
Raise your maximum Life to a safe level.
Continue searching vendors for improved helmets and shields.
Until you obtain the +2 Minion Helmet, every significant gold investment should continue moving toward that objective because it remains the strongest upgrade available under these restrictions.
Spend remaining passive points on practical Archon nodes rather than investing in flashy but inefficient passives that provide little benefit within the challenge's limitations.
Tips
Before beginning the challenge, configure your loot filter to hide every item except Gold and Waystones, preventing accidental pickups.
After completing each campaign act, revisit every town and refresh all vendor inventories before continuing.
Don't hoard your gold indefinitely. Whenever a major equipment upgrade appears, purchase it immediately. Early upgrades significantly reduce the difficulty of later campaign and mapping progression.
Core Benefits for Different Types of Players
Hardcore Challenge Players
Master every aspect of the Zero-Loot Challenge, from the campaign through the Atlas, and defeat both endgame Arbiters without repeatedly restarting failed attempts.
Standard POE2 Players
Develop disciplined resource management habits, eliminate wasteful gambling, and maximize the value of every resource, resulting in faster progression than players at the same stage.
Casual Challenge Enthusiasts
Experience a completely different way to play Path of Exile 2 without relying on the traditional loot system, making co-op challenge runs with friends both unique and rewarding.
Minion Build Players
Learn the most efficient route to obtaining a +2 Minion Helmet, allowing summoner builds to take advantage of their naturally low gear requirements and progress smoothly even under severe resource limitations.
Brak nowych postów MMOexp POE2 0.5 Immortal Ritualist Guide
Lilidala Przed zakupem 0 Dzisiaj 11:22
Lilidala
Brak nowych postów AB CUP i BMW-Challenge 2014
bobson Sport w FKP 11 16 Kwi 2014, 06:05
Brak nowych postów IV runda AB CUP i BMW-Challenge - Toruń - zapisy`
13. czerwca
Agniess Sport w FKP 0 4 Cze 2010, 23:26
Agniess
Brak nowych postów MMOexp Path of Exile 2 Version 0.5 Time Sorcerer Build Guide
Lilidala Przed zakupem 0 Dzisiaj 11:19
Lilidala
