Tagi tematu: cvh, instalacja elektryczna, komputer, mk3
18 Kwi 2011, 08:49
[MK3] CVH - Baza wiedzy :)
Mafios
Junior Admin
Imię: Patryk
Wysłany: 13 Kwi 2011, 19:53   [MK3] CVH - Baza wiedzy :)
czujniki powietrza
Przerobki instalacji CVH
Converting an 8v 2i loom to OFAB
1) At the ECU, pin no. 27 (marked on the multiplug, brown wire) needs moving to pin 8, which is empty (this is the CO adjuster signal wire).
2) Pin no. 45 (brown/yellow) needs moving to pin 27 - this is for the MAP sensor.
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAC ECU (pin 28 on ECU).
MAP Sensor re-wire:
At the MAP sensor multiplug...
1) Move the brown wire (gnd) to cossie MAP sensor pin no. 1 (marked on multiplug).
2) Move the brown/trace* wire (feeds back to ECU on pin no. 26) to cossie MAP sensor pin no. 2
3) Move the brown/yellow wire (feeds from pin no. 27 on the ECU) to cossie MAP sensor pin no. 3
4) On one of the Cossie MAP Sensors fixing holes there is a metal ring which goes into the sensor. This ring must be earthed, and when you mount the Cossie map sensor using the right brackets, it connects to earth. (You should only ever mount the Weber/Cosworth MAP sensors with the vacuum pipe pointing downwards).
Converting an XR2i loom to OFAC
1) Pin no. 8 (brown) needs moving to pin 27, which is empty (CO adjuster signal wire)
2) Pin no. 27 (brown/yellow) needs moving to pin no. 45
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAB ECU (pin 28 on ECU).
There are no MAP sensor pin changes as the OFAC MAP sensor is the same plug as the 2i MAP Sensor, so just plug and play.
OFAB to OFAC
Revert back to (OFAC) with these pin changes on the MAP Sensor. These changes assume you have the MAP sensor sitting with the part code (stamped in the side of the sensor) and plug locking latch facing you.
1) Move Cossie MAP pin no. 1 to pin no. 3 (brown).
2) Move Cossie MAP pin no. 2 to pin no. 1 (brown/trace*)
3) Move Cossie MAP pin no. 3 to pin no. 2 (brown/yellow)
FIESTA TURBO podcisnienia
RS TURBO
Ostatnio zmieniony przez bidżej 14 Kwi 2011, 06:42, w całości zmieniany 1 raz
stafcio
Wysłany: 20 Lis 2011, 22:36
zrobiłeś według tego? sprawdza się?
stafciogarage@gmail.com
Mafios
Junior Admin
Imię: Patryk
Wysłany: 21 Lis 2011, 10:41
sprawdza sie :) jak chcesz pomocy wal na PW ;)
RS TURBO
Brak nowych postów Ogłoszenie: Baza noclegowa - rezerwacja miejsce
JAK DOJECHAĆ NA ZLOT.... STRONA 1
trzeci IX Wiosenny Zlot / 01-03.05.2013 / Tor Kielce 123 29 Kwi 2013, 21:46
Obywatelka Higienistka
Brak nowych postów Przyklejony: Baza noclegowa - rezerwacja
Faza X Wiosenny Zlot FKP - Tor Kielce / 02.05.2014 64 29 Kwi 2014, 22:34
Brak nowych postów Przyklejony: Baza noclegowa na czas zlotu
Informacje i rezerwacje miejsc
trzeci V Wiosenny Zlot FiestaKlubPolska - Ułęż 2009 / 29-31.05.09 99 29 Maj 2009, 10:17
a1topgear
Brak nowych postów Przyklejony: Baza noclegowa na Zlot - rezerwacje domków
trzeci Zlot FKP - Tor Poznań 10.05.2008 182 4 Maj 2008, 16:52
sowa
Brak nowych postów Przyklejony: Zlot 2017 - Baza noclegowa / rezerwacja miejsc
vegetagt XIII Wiosenny Zlot FKP - Rudniki 2017/ 12-14.05.2017 26 7 Maj 2017, 06:52
