Przesunięty przez: molu
4 Kwi 2008, 09:34
Poszukuje informacji na temat MB Quart...
jaczylibodzio
Wysłany: 27 Lip 2006, 22:36   Poszukuje informacji na temat MB Quart...
Taaaa, mam glosniczki na przod, 16cm, MB Quart i nie moge znalezc o nich zadnych informacji. Model: D wc 160 . Jakby ktos cos znalazl na ten temat to piszcie...
jaco11
Wysłany: 28 Lip 2006, 18:12
Szukałem szukałem i nic w sumie nie znalazłem ale popatrz moze cos Ci pomoze pozdr... http://83.19.103.166/sear...f6c88dad91fbdf6 :D
Córcia JOA11
jaczylibodzio
Wysłany: 29 Lip 2006, 08:56
Bida, nic nie znalazlem, moze zle szukalem?
molu
Wysłany: 29 Lip 2006, 14:03
Ja tam sie sie znam ale to chyba sa wofery z zestawu DSD 216:
"MB Quart Discus DSD 216
The 6˝-inch MB Quart Discus DSD 216 ($399) is the big man in this group, with a woofer half an inch larger than the other two woofers. (By the way, you may know that MB Quart was acquired by Rockford Fosgate last year.) The Discus system features the DWC 160 woofer (with polypropylene cone, rubber surround, and stamped basket), the RTC 19 3/4-inch "pure titanium dome" tweeter (with neo-dymium magnet), and the DXD 216 crossover. The latter—3Ľ x 1Ľ x 5 inches (w/h/l)—has a clear plastic cover and 12-dB per octave high- and low-pass filtering. Its barrier strip with three tweeter levels (0, –3, and –6 dB) is accessible from outside the case. The barrier-screw terminals on the woofer basket are a nice touch (avoiding the need for you to have to worry about crimping or soldering).
The MB Quart system comes packaged with metal grilles for both drivers, a plastic woofer-mounting ring, an installation guide, and a cutout template, not to mention surface, flush, and tilt-flush tweeter-mounting cups. Hardware is supplied, but the wiring isn’t.
Specifications include a frequency response of 40 to 32,000 Hz (no tolerance in dB was given), a sensitivity of 89 dB, and a "power range" of 50 to 120 watts. Warranty is 3 years if the speakers are installed by an authorized dealer; otherwise, 1 year. MB Quart Sound Quality
The MB Quart DSD 216 delivered a clear, natural, and detailed tonal balance. Male vocals—such as an outdoor recording of ME Senior Contributor David Clark—were natural, and the ambience of the recording was faithfully reproduced. Likewise, reproduction of female vocals and acoustic instruments (such as Jennifer Warnes’ singing and Paul Ostermayer’s accompanying tenor saxophone on the title track to Warnes’ Famous Blue Raincoat, on Private Music) was virtually indistinguishable from the sound of it on my reference home-theater system. Likewise, the reverb added to Suzanne Vega’s vocal on "Tom’s Diner" (from Solitude Standing, on A&M) was clearly audible, with tonal balance perfectly following the vocal. Similarly, massed voices in chorale pieces were often individually distinguishable. "
jaczylibodzio
Wysłany: 29 Lip 2006, 20:43
Nie to, ale przydatne dane, bycmoze wofer zmienie i moze mi sie to przydac :) Dzieki za checi, czekamy dalej, moze cos ktos jeszcze wygrzebie...
Brak nowych postów Ogłoszenie: Podstawowe informacje na temat zlotu
Miejsce na pytania i odpowiedzi
trzeci VI Wiosenny Zlot FiestaKlubPolska - Rallyland Debrzno 2010 18-20.06.2010 78 18 Cze 2010, 07:12
Brak nowych postów Ogłoszenie: Informacje od Organizatorów na temat Zlotu
oraz pytania i odpowiedzi
trzeci Radom 2007 28 25 Kwi 2007, 07:24
Brak nowych postów Ogłoszenie: PODSTAWOWE INFORMACJE NA TEMAT ZLOTU
a także miejsce na pytania do organizatorów
trzeci V Wiosenny Zlot FiestaKlubPolska - Ułęż 2009 / 29-31.05.09 168 11 Cze 2009, 09:51
Brak nowych postów Przyklejony: Dyskusja na temat ZG 2006 / Hyde Park
Lużne wypowiedzi na temat Zlotu
Gość Zielona Góra 2006 144 28 Kwi 2006, 20:11
jaco11
Brak nowych postów [MK3] Silnik krokowy - potrzebuję informacji...
Tommy Elektryka 5 31 Sty 2009, 14:19
soldu
