Motorstate
Wiek: 29 Dołączył: 24 Kwi 2025 Posty: 6 Skąd: Ukraine
Wysłany: 22 Maj 2025, 16:33 Ford Sync2 F11 SD Europe 2023
Ford Sync 2 F10 2021 (without pass) + Sync2 F11 SD Europe 2023 (with pass)
List of countries:
Austria, Albania, Andorra, Belarus, Belgium, Bulgaria, Bosnia and Herzegovina, Hungary, Germany, Denmark, Gibraltar, United Kingdom, Greece, Ireland, Spain, Italy, Latvia, Lithuania, Liechtenstein, Luxembourg, Macedonia, Monaco, Netherlands, Norway, Poland, Portugal, Russia, Romania, San Marino, Serbia, Slovenia, Slovakia, Turkey, Ukraine, Finland, France, Croatia, Czech Republic, Switzerland, Sweden, Estonia, Sweden.
Сar list:
Ford Mustang 03.2015-03.2016
Ford Mondeo 10.2014-03.2016
Ford C-MAX 06.2015-08.2016
Ford S-MAX 05.2015-03.2016
Ford Galaxy 05.2015-03.2016
Ford Ranger 10.2015-04.2016
Ford Kuga 10.2015-08.2016
Ford Tourneo Connect 08.2015-05.2016
Ford Transit 01.2016-09.2016
Ford Transit Connect 08.2015-05.2016
Ford Edge 2011-2016
Ford Explorer 2011-2016
Ford Focus 2011-08.2016
Ford Escape 2011-2016
Ford Flex 2011-2016
Ford Fusion 2011-2016
Ford Taurus 2011-2016
Ford F150 2011-2016
Lincoln MKS.MKT 2013-2016
Lincoln MKX 2011-2016
Instruction:
We insert the card into the computer, format it in FAT32.
We find out the serial number of the SD card. USB readers are categorically not suitable for reading. To do this, insert it into the phone, download something from the SD-booster series, write down the number. Generate the key using GenFordKey.exe. To do this, enter the serial number, put the label "type of number - hexadecimal", we throw the resulting file into the root of the card. There is also a FordActivator program - the latter generally immediately creates the SdCard.key file on the inserted Sd-card by its number.
Unpack the downloaded archive with maps to the root of the map.
We insert the card into the slot in the car. If the key is not generated correctly, an error message will appear at startup.
The next time you replace the archive of cards on the same flash drive, we use the same SdCard.Key file.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass. |
_________________ I can help to install diagnostic/repair programs for cars, trucks, special vehicles and select diagnostic equipment/chip tuning. |
